How Stonehenge was Built?
Post new topic   Reply to topic    9/11, 7/7 & the War on Freedom Forum Index -> Other Controversies
conspiracy analyst
PostPosted: Mon Dec 10, 2007 10:39 pm    Post subject: How Stonehenge was Built? Reply with quote
http://snarfd.com/2007/12/07/stonehenge-the-incredibly-simple-secret-o f-how-it-was-built/
marky 54
PostPosted: Tue Dec 11, 2007 4:19 am    Post subject: Reply with quote
just the information i needed, nice find. im currently looking into ancient civilisations and a part of the mystery is how they managed to move huge rocks and stones around which in itself sparks of 'theorys'.
but there is no doubt if one man can do what is seen in that video then a group of 20 people per rock could move something bigger using the same technics, and this could possibly be the answer and makes sense as he only used materials avalible to people at those times.
and to think we build polluting things to do the job when nature with the right technic works just fine, all be it longer, but proof nature works just fine.
telecasterisation
Banned
Banned
PostPosted: Tue Dec 11, 2007 9:37 am    Post subject: Reply with quote
Not a good example to show using nice flat American concrete - try turning a 10 ton block around with a stone underneath it on wet english soil - the stone would simply be pushed into the ground.
I completely challenge the official version of events - I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC -I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC
Last edited by telecasterisation on Tue Dec 11, 2007 1:38 pm; edited 2 times in total
PostPosted: Tue Dec 11, 2007 10:09 am    Post subject: Reply with quote
This is the vid - but don't romanticise Stonehenge
It and it's Celtic & Druidic human sacrifice were used for mind control and abandoned for all good reasons.
Link
Lee
PostPosted: Tue Dec 11, 2007 1:13 pm    Post subject: Reply with quote
Impressive work by that very handy-man.
But, I always thought the real mystery was not how...but why?
I saw an interesting doc about how, by unearthing strange ancient conical copper hats which chart the lunar eustaces, someone was able to prove that Stonehenge was built to resurrect the moon goddess over the encroaching sun god.
In modern terms, people were losing hope in life as agriculture took over from the night hunt. They were getting bored.
S'henge was an attempt to show how the moon was the truer god(dess).
marky 54
PostPosted: Tue Dec 11, 2007 1:53 pm    Post subject: Reply with quote
it varies depending which civilisation or which structure is being refered to.
like here for example:
http://video.google.co.uk/videoplay?docid=-8671073631187036272&q=gods+ are+arriving&total=18&start=0&num=10&so=0&type=search&plindex=1
sometimes the how and why are questioned.
PostPosted: Wed Dec 12, 2007 1:59 am    Post subject: Reply with quote
Stonehenge was abandoned wasn't it, way before the Romans came. I never understood exactly why.
Was it a common-sense Iron Age rejection of the nearest Britain ever came to the pyramids, vast slave-labour civil engineering programmes?
TmcMistress
Mind Gamer
Mind Gamer
PostPosted: Wed Dec 12, 2007 6:50 am    Post subject: Reply with quote
TonyGosling wrote:
Stonehenge was abandoned wasn't it... I never understood exactly why.
Come again? I'd also add that stories of Druidic human sacrifice are just as likely Roman propaganda.
"What about a dance club that only let in deaf people? It would really only need flashing lights, so they'd save a lot of money on music." - Dresden Codak
PostPosted: Wed Dec 12, 2007 2:15 pm    Post subject: Reply with quote
Romanes eunt domus.
Dissolution of the Global Corporations.
It's the only way.
It's them or us.
PostPosted: Wed Dec 12, 2007 7:58 pm    Post subject: Reply with quote
You must have missed the bit where he moved an entire barn 300ft across fields Tele.
But you're on the right 'track' - he did use the caterpillar track principle of laying a suitable surface ahead to travel over.
Whether he's right or not - and I see no technical reason why he shouldn't be, given the level of technology he uses - it's certainly a practical contender which successfully challenges the vast organisation of slave labour normally accepted as the method used.
Human ingenuity never ceases to amaze me.
It's the only way.
It's them or us.
telecasterisation
Banned
Banned
PostPosted: Thu Dec 13, 2007 5:06 pm    Post subject: Reply with quote
No, didn't miss the barn, I ignored that as that was an even worse example. If you look at the video, you only see him swivelling a building with no bottom/floor. Are we suggesting he raised the building and put a rock under it then moved it by the principle he suggests?
Every example on film shows a nice flat even concrete base - if there were huge stones moving across damp uneven muddy soil then it would be worth taking note - there simply isn't, so it has yet to be demonstrated.
telecasterisation
Banned
Banned
PostPosted: Thu Dec 13, 2007 5:07 pm    Post subject: Reply with quote
No, didn't miss the barn, I ignored that as that was an even worse example. If you look at the video, you only see him swivelling a building on a flat even base. Are we suggesting he raised the building and put a rock under it then moved it by the principle he suggests?
PostPosted: Thu Dec 13, 2007 5:37 pm    Post subject: Reply with quote
Just so, and the trick - just like with the tank track principle - is to lay a flat base across the terrain for the roller technique to work, probably ripping it up behind them and relaying it ahead of the direction of travel.
For that reason, I still think he may be on to something.
It's the only way.
It's them or us.
Piioottrr
PostPosted: Mon Nov 05, 2012 11:03 pm    Post subject: Reply with quote
Google translate from Russian. Lots of pictures
Stonehenge was built in 1954
http://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http%3A%2F%2 Fss69100.livejournal.com%2F513319.html
Andrew.
PostPosted: Thu Nov 08, 2012 7:17 am    Post subject: Reply with quote
http://en.wikipedia.org/wiki/Stonehenge
Further it was a calendar, also for the 7th year and end of the 50th year too.
Something the diggers and levelers (and many others) would have been interested in, had they have known.
PostPosted: Mon Jul 02, 2018 10:04 am    Post subject: Reply with quote
Wiltshire Times
PICTURES: Crowds gathered at Avebury and Stonehenge for Summer Solstice
Stacey Turnbull @StaceyNewsWilts
http://www.wiltshiretimes.co.uk/news/16305188.pictures-crowds-gathered -at-avebury-and-stonehenge-for-summer-solstice/
THOUSANDS gathered to watch the sun rise at Stonehenge and Avebury this morning to welcome the longest day of the year.
Solstice-watchers were blessed with clear-skies as they watched the day break.
The sites hold special significance for members of the Druid and Pagan community, who perform rituals and celebrations at the summer and winter solstices.
Around 600 people joined in the celebrations in Avebury.
Two people were arrested at Avebury, a 30-year-old man for being drunk and disorderly, and a 25-year-old man was arrested for drink driving.
Superintendent Dave Minty, said: " We are really pleased with how Solstice 2018 has gone, it really has been a great success.
"English Heritage welcomed approximately 9,500 people at Stonehenge, and the majority of those who came to celebrate the longest day of the year did so in a safe and peaceful manner.
"There was a really great atmosphere and we are really pleased to say there were no arrests at Stonehenge.
"Approximately 600 people joined the celebrations in Avebury which also saw the public embracing the spirit of Summer Solstice. Two people were arrested at Avebury, a man age 30 was arrested for drunk and disorderly, and a man age 25 was arrested for drink driving.
"The joint approach to planning the event with Wiltshire Council, security staff, the Highways Agency and English Heritage is key to ensuring visitors to Summer Solstice have a safe and enjoyable time and we look forward to Solstice 2019."
Artist Tom Yendell from Hampshire, was amongst the thousands who flocked to Stonehenge at sunrise today, capturing the moment the sun rises behind the Heel stone in a painting using only his mouth, a set of watercolour paints and the iconic landscape behind him.
Mr Yendell, who is an active board member for the Foot & Mouth Painting Artists wanted to create an entirely unique, innovative painting that depicted the significance of Stonehenge.
He said: “Stonehenge is a monumental British landmark which I have been keen to paint for years.
"Painting live at Summer Solstice was the perfect opportunity to celebrate the 100th anniversary and create memories for years to come.
"It has been a privilege to share the work we do as members of the Mouth and Foot Painting Artists with the general public at such an iconic location.”
Post new topic   Reply to topic    9/11, 7/7 & the War on Freedom Forum Index -> Other Controversies All times are GMT
