| View previous topic :: View next topic |
| Author |
Message |
flamesong Major Poster
Posted: Tue Nov 07, 2006 11:22 am Post subject: |
Err... no, I don't think I'll bother.
I've played this game with you before, Ally. Y'know, Go-Fetch™.
You want to prove a point, you get the evidence.
As far as the David Copperfield did it theories go, I kept my mind open long enough to see that every bit of evidence presented is flawed by a poverty of analysis. For me the case is closed.
| Back to top |
Ally Moderate Poster
| Back to top |
Posted: Tue Nov 07, 2006 12:36 pm Post subject: |
| But, Ally, I don't find it at all surprising that remnants of the fuselage passed through the building, obviously between floors, and were then blown apart by the pursuing fireball. The close up in the video shows the 'exit' is to the left of the building's corner. The photo you uploaded does not, in my view, show enough detail to the left of the corner to disprove that remnants of the fuselage had 'exited' there.
| Back to top |
| Back to top |
telecasterisation Banned
Posted: Tue Nov 07, 2006 2:04 pm Post subject: |
| flamesong wrote: | | But, Ally, I don't find it at all surprising that remnants of the fuselage passed through the building, obviously between floors, and were then blown apart by the pursuing fireball. The close up in the video shows the 'exit' is to the left of the building's corner. The photo you uploaded does not, in my view, show enough detail to the left of the corner to disprove that remnants of the fuselage had 'exited' there. |
The nosecone of the aircraft in question is relatively quite flimsy. Having passed through the building, the image of 'it' emerging apparently unscathed and in a recognisable shape out through the opposite side stretches the bounds of what is acceptable.
This hardly constitutes a 'remnant' as it is clearly what appears to be the front of the aircraft, seemingly in pristine condition and not just a photocopier that happened to be forcibly ejected.
_________________ I completely challenge the official version of events - I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC -I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC - I AM NOT A 9/11 TRUTH CRITIC |
| Back to top |
Posted: Tue Nov 07, 2006 3:12 pm Post subject: |
I don't see evidence for much more than blurred remnants in frames 100 to 103 of this much enlarged close-up. If you want to debate about what may be little more than a lump of wreckage, go ahead.
Incidentally, is it not likely that the nose cone was made of carbon fibre? A substance which, prior to kevlar, was used in bullet proof vests.
I was also reliably informed in a meeting with Dr. Piotr Bein , Ph.D., M.A.Sc., P.Eng, that depleted uranium has been used as ballast in many commercial planes - especially by Boeing. It was phased out in the 1980's but the 767-200 was launched in 1978. As depleted uranium is used to tip 'bunker busting' missiles, I don't think I need extrapolate on its credentials.
| Back to top |
Posted: Tue Nov 07, 2006 3:50 pm Post subject: |
I'm sure you've seen the damage a bird can do to an aircraft -
Yet the inside WTC was plated with this -
you think the plane could penetrate multilayers of that steel case?
| Back to top |
Posted: Tue Nov 07, 2006 4:21 pm Post subject: |
So, what do you think should have happened if a plane hit the WTC, then?
Would it have bounced off and landed in a big shìtty heap on the ground?
Or stuck out like a paper dart sticking out of an air vent?
You make it sound like I am claiming the plane virtually flew through the building and out of the other side - that it patently not the case. But I believe that it is possible that a huge lump of it may have done - probably composed of bits which passed between the uprights and floors.
| Back to top |
Posted: Tue Nov 07, 2006 5:21 pm Post subject: |
Ally wrote;
| Quote: | | I'm sure you've seen the damage a bird can do to an aircraft. |
The bird in question was Roseanne Barr though.
Anyway, to the emerging nosecone.
The body of a 767 is 4.7 m in height, but the distance between floors of the WTC was only 3.7m - it is physically impossible for the light aluminium nose of the aircraft to travel through and out the other side as a recognisable shape, given the width clearance available even on floors with completely clear floor space.
It would have been torn to pieces immediately upon entry.
| Back to top |
chek Mega Poster
Joined: 12 Sep 2006 Posts: 3889 Location: North Down, N. Ireland
Posted: Tue Nov 07, 2006 5:45 pm Post subject: |
| telecasterisation wrote: | Ally wrote;
It would have been torn to pieces immediately upon entry. |
It's the 'recognisable shape' bit I have a problem with, for the reasons you state.
Suggestive shape possibly, but something about it - the brightness gain for one looks wrong.
I'd want to see the original video before taking a stab at what it might be.
| Back to top |
mason-free party Moderate Poster
Joined: 30 Jul 2005 Posts: 765 Location: Staffordshire
Posted: Tue Nov 07, 2006 8:28 pm Post subject: |
I think Andrew has a point here...there is more to this video fakery than meets the eye
| Back to top |
THETRUTHWILLSETU3 9/11 Truth critic
Posted: Tue Nov 07, 2006 10:22 pm Post subject: |
There is one point you all appear to have overlooked
Ghost planes are very fuel efficient - there would be no explosion of jetfuel upon impact.
Therefore the fact there was no explosion of jet fuel on the impact side of WTC is consistent with a ghost plane
Simple Innit stating the Bl eeding obvious
| Back to top |
andrewwatson Moderate Poster
Posted: Wed Nov 08, 2006 8:29 am Post subject: |
I agree with Ally about the exit wound being far too small to contain the large 'sausage' which shoots out of the south-east corner in several videos.
The problem is that the videos are remarkably consistent , which makes the idea of them having been faked seem less likely. It's weird.
| Back to top |
Posted: Wed Nov 08, 2006 9:22 am Post subject: |
Don't we simply get a side view of the 'sausage', hence no guarantee it is circular or accurate dimensions.
In addition, there was the aircraft/jet engine that came down in Murray St - was this simply dropped off the back of a lorry in the confusion, or kicked out from underneath a hotdog stall, or taken up the WTC in pieces, reassembled and then fired out of the windows via a rocket propelled sled?
| Back to top |
Posted: Wed Nov 08, 2006 1:44 pm Post subject: |
The engine part was photographed underneath some scaffolding . It may well have been moved from its landing site by forensic experts , or alternatively it could have been planted there when the streets were relatively quiet in the early morning/night. I know Killtown believes it was planted.
This site has a fair bit about it:
http://www.911foreknowledge.com
as does this one:
http://www.maebrussell.com/9-11/Dear%20World%20Watcher.html
| Back to top |
Posted: Wed Nov 08, 2006 5:31 pm Post subject: |
As many will have seen from the earlier part of this thread, great focus was made of the comparison drawn between the bomber crashing and the WTC collision/s.
Having gone back and looked at the bomber crash, you will see from the attached image that the bomber's wing actually 'explodes' PRIOR to hitting the ground/runway. It very much seems to hit what appears to be possibly cabling raised above the ground - this could easily be high voltage cabling and tends to negate any direct comparisons drawn.
Until this aspect is disproved, I stand firmly by my belief that the WTC fireball appeared quite rightly only after the aircraft had entered the building.
| Description: |
| Filesize: |
16.85 KB |
| Viewed: |
14 Time(s) |
Last edited by telecasterisation on Wed Nov 08, 2006 5:45 pm; edited 1 time in total |
| Back to top |
Snowygrouch Validated Poster
Posted: Wed Nov 08, 2006 5:34 pm Post subject: Fuel |
I suppose nobody noticed 10,000 gallons of jet fuel in barrels sitting around in the office that morning?
_________________ The potential for the disastrous rise of misplaced power exists, and will persist
President Eisenhower 1961 |
| Back to top |
chek Mega Poster
Posted: Wed Nov 08, 2006 5:57 pm Post subject: Re: Fuel |
| Snowygrouch wrote: | | I suppose nobody noticed 10,000 gallons of jet fuel in barrels sitting around in the office that morning? |
Didn't William Rodriguez mention some 'vending machine guy' in the North Tower that day
| Back to top |
Patrick Brown 9/11 Truth critic
Posted: Wed Nov 08, 2006 6:04 pm Post subject: Re: Fuel |
| chek wrote: | | Snowygrouch wrote: | | I suppose nobody noticed 10,000 gallons of jet fuel in barrels sitting around in the office that morning? |
Didn't William Rodriguez mention some 'vending machine guy' in the North Tower that day  |
Yeah chek but they were Coke cans!
_________________ We check the evidence and then archive it: www.911evidencebase.co.uk
Get the Steven E Jones reports >HERE< |
| Back to top |
Andrew Johnson Mighty Poster
Posted: Wed Nov 08, 2006 6:19 pm Post subject: |
| telecasterisation wrote: | Having gone back and looked at the bomber crash, you will see from the attached image that the bomber's wing actually 'explodes' PRIOR to hitting the ground/runway. It very much seems to hit what appears to be possibly cabling raised above the ground - this could easily be high voltage cabling and tends to negate any direct comparisons drawn.
I am glad you're paying attention. What would have caused it to explode without hitting anything? (and why would the WTC NOT explode when it clearly HAD hit somethig?)
It is quite difficult to tell from the "bomber crash" video, but looking at the structures to the left of your ring, I'd say they were pylons. I therefore deduce that the explosion was caused by the plane wing clipping either the pylon or the power cable.
Other's can go with TC's explanation if they feel it is more legitimate.....
_________________ Andrew
Ask the Tough Questions, Folks!
Last edited by Andrew Johnson on Wed Nov 08, 2006 6:21 pm; edited 2 times in total |
| Back to top |
Posted: Wed Nov 08, 2006 6:20 pm Post subject: Coke |
Ah thats it!!!
Secretly the CIA had coca cola make a batch of 200,000 cans filled with kerosene, cunningly installed 2000 vending machines filled with said cans on the correct floors and positions and the rest is history!
Or..........................................not.
Come on guys!
| Back to top |
Posted: Wed Nov 08, 2006 6:35 pm Post subject: Re: Coke |
| Snowygrouch wrote: | Ah thats it!!!
Come on guys!  |
And when the truth comes out ( ) they will discover the Coke was mysteriously sent to 7 WTC!
Well those CIA types like their drugs don't they?
| Back to top |
chek Mega Poster
Posted: Wed Nov 08, 2006 6:54 pm Post subject: Re: Coke |
| Patrick Brown wrote: | | Snowygrouch wrote: | Ah thats it!!!
Come on guys!  |
Well those CIA types like their drugs don't they?  |
Y'see? All it takes is some 'critical thinking' and it all comes together!!
| Back to top |
Posted: Wed Nov 08, 2006 9:09 pm Post subject: |
Andrew Johnson wrote;
| Quote: | | I am glad you're paying attention. What would have caused it to explode without hitting anything? (and why would the WTC NOT explode when it clearly HAD hit somethig?) |
You've lost me with this question, I clearly stated and you quoted me;
| Quote: | | It very much seems to hit what appears to be possibly cabling raised above the ground... |
So I clearly already stated that it looks to have hit the cables. Did you simply not read it or were you being rhetorical? I have no idea what would cause it to explode without hitting anything, electrical fault, a bomb, why does any aircraft ever catch fire or explode independent of a collision?
However, I never said it didn't anything, I said it looks to have hit something before it hit the ground.
| Back to top |
dry kleaner Minor Poster
Posted: Wed Nov 08, 2006 10:50 pm Post subject: |
To me the B52 looks like it fell on to its fuel in the wing and then BANG!
Peace and love
DK
_________________ Just one more thing..... |
| Back to top |
Posted: Wed Nov 08, 2006 11:10 pm Post subject: |
TC - sorry - I didn't read all your post on this one. Apologies.
Electrical cabling - well - yes - we concur on that then. I don't think it makes the comparison any worse than I originally suggested in my 1st post with the video - but I still think it is a fair comparison - the "delayed fireball" is extremely obvious to me and I have noticed it in all 3 videos of the 2nd impact I have seen up to now.
Again sorry for my previous error.
Ask the Tough Questions, Folks! |
| Back to top |
Bicnarok Moderate Poster
Posted: Fri Nov 10, 2006 3:58 pm Post subject: |
I don´t understand what some women waving or people standing in the hole of the tower have to do with a "no planes" theory.
It seems logical that if your trapped in a building in a disaster situation you will want to get out, a big hole in the bulding seems the logical possible way of escape. Maybe some helicopter can lower some cable or something to lift the person out.
Going to the roof wouldn´t be possible because heat rises and the roof would probably be well hot, if accessable at all. Going down seems an unlikely possibility seeing as the impact may have damaged the escape root, stairs (if there were and at all in the WTC?) So a big gaping hole seems like a good possibility of surviving.
_________________ "Emancipate yourself from mental slavery, none but ourselves can free our mind..." Bod Marley |
| Back to top |
Posted: Fri Nov 10, 2006 4:07 pm Post subject: |
| Bicnarok wrote: | | I don´t understand what some women waving or people standing in the hole of the tower have to do with a "no planes" theory. |
My understanding is that the point being laboured here (although the thread starter has done something of a U-turn now), is that if it had been a plane = lashings of aviation fuel burning.
This would mean it would be too hot for people to wander about sightseeing from the hole/s made, due to the high temperatures generated.
Not a new theory/standpoint, but what else do we have to discuss? Things are a trifle quiet of the new info front.
I have seen the Borat movie should anyone like a review.
| Back to top |
Posted: Sat Nov 11, 2006 11:18 am Post subject: |
| Bicnarok wrote: | I don´t understand what some women waving or people standing in the hole of the tower have to do with a "no planes" theory.
Going to the roof wouldn´t be possible because heat rises and the roof would probably be well hot, if accessable at all. Going down seems an unlikely possibility seeing as the impact may have damaged the escape root, stairs (if there were and at all in the WTC?) So a big gaping hole seems like a good possibility of surviving. |
I now think the woman waving was a fake shot...why didn;t they zoom in closer..the actual clip only lasted a few seconds i believe...very conveniently
| Back to top |
Posted: Sat Nov 11, 2006 11:23 am Post subject: |
I now think the woman waving was a fake shot...why didn;t they zoom in closer..the actual clip only lasted a few seconds i believe...very conveniently.
Can you elaborate as to why you believe it is fake? Is it just the length of the clip and the lack of zooming?
| Back to top |
