Yes, Kuttler does indeed say that, but I take that to be a disingenuous attempt to leave an opening for his friend Jones to come in and say that the reason for a lack of resistance was that key parts of the structure had been attacked with thermite, thermate, super nano thermate, or superduper imaginery thermate which might have been developed with convenient properties. Nowhere does he say that the building did
not fall in a pancake collapse, starting from the top, the collapse mode he assumes for his calculations. Reading his paper with no other knowledge of the event, one would naturally draw the inference that a pancake collapse was what happened, and take his calculation at face value. At best, his omission to mention the actual collapse mode of the building was ill-advised, at worst it was dishonest.
I cannot agree that his model is biased towards a shorter collapse time, he starts with the momentum of a single floor, which builds up floor by floor until all the floors are moving, and they all move together only at the end. What actually happened was that they all started moving together, the maximum momentum achieved under Kuttler's model, and momentum was lost as floors were successively crushed. This is what happens in a controlled demolition, so it is not surprising that it should look similar or take a similar time.
However, you are correct in that what is difficult to understand about the collapse is not actually the time it takes, but why failure should take place apparently across most of the width of the building virtually at the same time. It was always considered that probably the unique design of the building was responsible in some way, and an article in a recent issue of
Structure magazine, by someone who sounds like an informed insider to the NIST investigation, suggests a mechanism.
LINK. This sounds like the best theory put forward to date.
